Whenever I go to create a new sms, and press the cursor down (from Receipent to Message box below) to type my message the system pauses for about 10-20 seconds, then it remembers what I had started to type.
What does Shift Ctrl I (deletes Ini file) do exactly?
Any resolutions.
Many Thanks
N
It happens to me very often...I think it's a ram issue because after a while I get fed up and format the entire device and then it works ok! Don't bother deleting only the ini files,just format everything so that you have a new 9210i! I was about to post a new topiv�c for this ram issue...I wanted some advice...wait to se the topic! 😉
