I would like to backup my voice tags, ToDo list, and Internet settings.
After searching through C:\System\Data, I never came across a file name that I recognised.
Can anyone please help with the correct file names and where they are located...?
Backup Voice tags and other files locations
have you tried backing up with pcsuite? After a hard reset, you can restore to-do's, internet settings, contacts (+ voice tags), apps...
Paul
No PC available at the moment. Am using IR with PDA so can't use PCSuite.
Ideas anyone...?
Your "To-Do" list should be able to synchronise with the PDA, as for the others you need a PC with PCSuite
Bob
