How to re-format & re-install 9210 to factory default
1 replies · 2,438 views · Started 28 June 2002
Does someone has a step-to-step guide on how to restore the 9210 to factory default. I mean a complete cleanup, reformatting the C & D drive completely, then re-install all the files required as if its new from factory.
I assume it's same for all s/w ver but specifically v4.13.
Thanks a bunch!
Copy any data files you want onto MMC or PC.
Remove battery, replace after a few seconds.
Around when the graphics is about to/does first appear press Shift+Control+F.
Agree to format it.
Install All_Nokia_9210_ data.sis file to c drive. (Either from PC or having copied it to the device/MMC from control panel install/remove, new install)
Format the MMC card using the file manager now installed or delete all the contents. If there is data you want to keep, then just delete the system directory on the MMC card along with any other non data related directories. (To see system files, you have to pick the option from somewhere on the file manager)
Then install All_memory_card_data.sis to the D drive (MMC) using same method.
I suggest you get the 4.13 versions from the Nokia site.
To get everything to sync. nicely, delete and recreate the sync. tasks in PC Suite.
Hope that answers your question !
Zuber
