How to download programs from your PC to your phone
5 replies · 2,662 views · Started 13 May 2003
I have a nokia 3650 and I would like to know how to download and install applications that i have downloaded on my PC from the web.
I don't have WAP access and I could not find the data cable for the 3650
PLs. All help is appreciated
Pal, you need no cable. If you have a irDa port on your PC or you've got a BLUETOOTH adapter you can transfer files, apps or whatever OTA. With no cost at all...
Search the forum, for more information because there are many ways to do that. From transfering the .sis file to the phone and install it, to installing the app direclty from the PC using PC SUITE.
Yes... IRDA or BLUETOOTH will be the answers. Do a search coz a lot of people have been asking this question already 😊 And it's tiring to answer the same things over and over again. 😊
I use multimedia memory card reader from jessops. It cost me about eighteen pounds. It say's its only designed for images and video but if you display all hidden files you can do data.
