I want to write a simple terminal program with zmodem for the 9210.
But how do i use the serialport?
-A codesnippet would be great 😊
zapp,
Check this thread http//www.allaboutsymbian.com/phpBB2/viewtopic.php?t=11964 . It contains OPL code for the LAM-1 GPS unit that connects to the 9210's serial port. I'm sure that you will find what you are looking for there.
Regards
