PC Suite with WinXP home/pro?
1 replies · 1,663 views · Started 13 May 2003
Please help me with this... Why my PC Suite is not working... All the buttons are inactive.
I have installed PC Suite for p800 and I have MSI bluetooth with WINXP home...
-Make sure you have the latest drivers for your MSI BT dongle.
-Pair your phone and your BT dongle(Make sure to add all services expecially COM PORT connection)
-Check all the available BT Com ports on Mrouter(that small double sided arrow lifeline lookalike on your systray)
-Click on the Com Port connection to P800 service under Bluetooth services.
-You should then get an accept or reject connection on your P800, click on accept.
-Then the PC(this is the funny part, just go through it) will reject your connection.
-The Mrouter will accept it and you should then get this succesful
Bluetooth connection sound and the bluetooth ICON on your SYSTRAY should turn green.
The most important thing to check first is to install the right drivers of the BT dongle.
Hope this helps.
