m-Router not recognizing ports
5 replies · 3,165 views · Started 14 May 2003
Ok very frustrated here.
I'm having very sporadic success with m-Router. Sometimes, it is able to recognize ports and everything just syncs up fine.
Other times, I can't for the life of me get it to recognize potential ports.
Also, I keep getting the following error message:
Server Busy
This action cannot be completed because the other program is busy. Choose "Switch To" to activate the busy program and correct the problem.
Anybody out there experiencing the same thing or have any suggestions.
I've experienced this... I just reboot my system. What device are you using? Bluetooth or IR?
I'm running XP Pro SP1 and for the short term I'm just trying to get the IR going. I bought a USB bluetooth adapter, but that seems to have more/different issues.
Unfortunately rebooting doesn't seem to work for me. The weird thing is that usually just when I give up on it, it mysteriously connects. It makes me think there must be something to this "other program."
Of course, the error message doesn't really provide any insight.
To anyone out there experiencing a similar issue - check your personal firewall. It turned out that mRouter was somehow blocked by McAfee. Don't know why.
...Jamie
I starting to loose it, stupid mrouter just won't list other comport except infrared, i just once saw it list all ports but the next day they were all gone, after that, i resinatlled OS, PC suite, Bluetooth software the whole, at least 4 times over and over again?? I don't have any firewall running, also disabled XP firewall, can ANYONE please help ????
