Alarms
2 replies · 1,564 views · Started 14 May 2003
Hi All
Does anyone know of an alternative clock application with a better alarm than the default on the 3650?
The problem isn't the alarm itself, just the amount of snoozes available. I like to be woken up and then snooze between say, 6 or 7 snoozes. (roughly 40/45 mins) Problem is, with the default alarm, you can snooze about 3 or 4 times (roughly 25 mins or so) and then it just switches off. Now this can be a problem as I tend to then wake up about 30 min later in a flat panic.
Yes, yes, I know I'm lazy and should wake up on the first ring, but *shrug*
Sorry mate,
Don't know of any software. But have you thought of setting 2 alarms? 1 for your first 3-4 snoozes. And another roughly 25 minutes ahead of the first.
Just in the interim before somebody comes up with a better answer 😃
