How far does your irremote go ??
6 replies · 2,003 views · Started 14 May 2003
hi,
i read somewhere that a guy can control devices up to 3 meters with his 3650. My phone reaches only about 0.5 meters with the irremote. How far can you control from your 3650 ??
I've found it varies with the device I'm using it with and 3650 battery condition, but I can generally get 1.5m
A friend with a 7650 seems to have more luck - something to do with the positioning of the IrDA port maybe?
lol, what did you do then in the hifi store? 😊 fucktup up the tv's and radios? or just put them on different channels, or popup the volume?
teres a reply from PsiNT on this
Dear Sir,
Version is correct - engine is 0.96, remote definitions is 0.97.
Range may be higly improved by replacing IR diode to high power one - we were tried with external IR diode and range was ~20 meters.
Yes, removing black window (or better replacing with glass) is a good idea, we will try to find some hardware manufacter able to produce such accessory.
Please provide list of brands you want to be included.
Best regards,
Technical support team
PsiNT (PSILoc)
Poland
Phone: +48-94-3477766
Web: http://psiloc.com
Email: mailto:[email protected]
-----Original Message-----
Sent: Friday, May 02, 2003 12:35 AM
To: [email protected]
Subject: IR remote
I just download your latest version 0.97B and sent it to my phone (nokia 3650) but when I go to the about window it still says 0.96(0) I tried removing it and doing it again but the same thing. is this right.
Also is there any way to get longer range. even if its some and hardware you add inside the phone.
please more U.S. brands
Other than that I will but it soon.
thanks
P.S. I tried removing the little black window on the side and the range was 2X as good but I don't want to leave it out
does anyone make a clear one
