Problem with JAVA applications
2 replies · 1,669 views · Started 14 May 2003
I installed about 10 java apps and it slowed down entering to apps folder, is that normal, how can I speed it up?
... and how do you speed it up? Simply uninstalling the applications doesn't work. The folder still takes ~1 minute to open up.
Anyone?
