I was just playing around with my 3650,deleting few files through seleQ
and then i restarted it and when it turned on i couldnt open anything the options i got a system error message
and when i took the mmc out and then turned it on everthing worked perfectly.....now im worried if this is my phones problem or mmc's problem?
if i get a new mmc will everything work fine?
and if i use a mmc reader to format the mmc will everything work again?
System Error!!!
I think you shouldnt worry,its error occured because of the contacts(electric side)of the MMC card.
ah man fixed it :P
i bypassed the starting apps by holding the abc button
and then formated the mmc :P
and just installed all the apps back hope I wont get the error again
ill be getting my 128 mb at the end of this month
Good luck
