All I know is that there is a copyright proptection on it, but what does it protect - your files or will not let you put downloaded music on it?
What is special about magic gate?
Please search before starting a new thread, this has been covered many times.
Basically the magic gate feature makes no difference on the P800 because the P800 doesn't support the magic gate feature. -That was a bad explanation.. :-? , but you don't have to worry about any copyright issues when using magic gate in the P800, you can download all the MP3's(or whatever) you wan't into it. 😊
Hey...Its Magic
it's (magic) price maybe? 😮
[quote="mkouk"]it's (magic) price maybe? 😮[/quote]
You'll never be able to check if they are more expensive since there are no "normal" 64 and 128 Duo cards...
it was meant to be a joke about their generally excessive price for memory sticks duo! 8)
