Hi all !!
I would like to know if it is possible to change original icons on the Nokia 3650 (for example, the Tools folder icon or the Sim folder icon) ?
I tried SmartLauncher and its Skineditor sofware but it's not really want I want to do.
Is there, somewhere in the "system" or "nokia" folder, a file which is the icon file or something like that ?
thanx 😉
No, cant be done that way.
Get sLauncher, or better yet wait a while and get similar app maybe for free from one of our moderator j2k.
yeah get sLauncher very good app! 😊 two thumbs up
But i dont like that programm,it is too colored.
[quote="jimmy-floyd"]But i dont like that programm,it is too colored.[/quote]
I don't like it either, too much memory for just some "looks" with no functionality upgrades. IMHO.
Two mans,who doesnt like this prog.
[quote="JyriK"]No, cant be done that way.
Get sLauncher, or better yet wait a while and get similar app maybe for free from one of our moderator j2k.[/quote]
Thanks for the plug JyriK 😉
Yes, "Icon Changer" standalone should do what you want. You will design the icons on the PC and send the .SIS file to the phone, which will change the icons.
Cheers
So,moders can close topic. :black:
I dont see why should we close the topic. BTW: The program,sLauncher by itself is not colored,its skins are,so if you want a non colored skin you can make it your self with no trouble at all.For the purpose of changing only the folder icons only,Icon Changer would be more suitable.
