Messages/ Emails
2 replies · 1,579 views · Started 02 July 2002
Hi there guys,
I hope anyone knows, say at least roughly, the old PSIONs with its MessageSuite?
For my question it is important to know how it treated inbox and remote mailbox folders;
You could also have different mail accounts and upon connecting the S5 showed you all the mails currently waiting on the remote server.
AND with all date and file infomation such as KByte or MByte.
My question is can I have such info on the 9210, too?
And if yes, how do I do the configuration?
Thanks in advance,
Ralf
I have not used PSIONS message suite. However the 9210 works in the way you describe and gives you the message size and subject before you have to download the message.
The only (big) difference between the Nokia and the Psion mail applications is the way the remote mailbox is handled.
On the Psion, one opens the remote mailbox, get a list of available messages and the select the ones to download and the ones to delete. Downloaded messages are moved to the inbox.
On the Nokia, it is similar, except that downloaded messages stays in the remote folder.
Chris
