Hello, i need telnet for my P800.
I try Putty, but is not a really usable product. There isn't scroll up and down.
I try Mutelnet, write in j2me, but when i write text, it not send to a server.
Help me, i find disperatly for my job.
Thz in advanced.
Thz in advanced.
I'm a fraid that those are your only options for now.
I am sorry to say that GhostDog appears to be right at the moment.
I am also keen to get ssh/telnet working and I have had exactly the same problems as you. Putty works but the lack of control characters unfortunately makes it impractical to use. I couldn't persuade muTelnet to work either.
I just installed my free (just for filling in a tedious survey) copy of CodeWarrior Wireless IDE so I shall have a look for the source for muTelnet and see if I can figure out what's wrong. However, if your job depends on it, I suggest you look for other options... 😞 .
