Hi all,
Is there a way to get this IDE ?
I found no trial download on metrowerks website !
Thanx
CodeWarrior Studio for Symbian OS v2
I downloaded for nothing something that describes itself in help->about as "CodeWarrior IDE Version 4.3.0.891". I only d/l this last night just before I went to bed and I haven't had the opportunity to play with it yet, but I believe it's just a Java IDE so you couldn't develop C++ apps with it.
A developer friend of mine pointed me here:
http://kb.motorola.metrowerks.com/motorola/developmentTools.do#codewarrior
You have to join the MOTOCODER Program, but all you have to do is provide your personal details. Then you have to fill in a survey for Metrowerks and bingo, you get a full licence for nothing.
That IDE you get when you join motocoder is useless. It's for Java development only (pJava & MIDP). If I want an IDE for pJava & MIDP development, I'd use Borland's or Sun's IDE.
I don't think there is a downloadable trial, however a trail version appears to be included on the CD of the new Symbian C++ book due to be published 22 May. Book looks good if you are not yet very familiar with Symbian C++.
[quote="Anonymous"]That IDE you get when you join motocoder is useless. It's for Java development only (pJava & MIDP). If I want an IDE for pJava & MIDP development, I'd use Borland's or Sun's IDE.[/quote]
Er, yes I did say that it was just for Java in my post. Are the IDEs from Borland and Sun free?
[quote="slangley"][quote="Anonymous"]That IDE you get when you join motocoder is useless. It's for Java development only (pJava & MIDP). If I want an IDE for pJava & MIDP development, I'd use Borland's or Sun's IDE.[/quote]
Er, yes I did say that it was just for Java in my post. Are the IDEs from Borland and Sun free?[/quote]
Actually you said [quote="slangley"]but I believe it's just a Java IDE so you couldn't develop C++ apps with it[/quote] so I merely confirmed that yes, it's just for Java. Sun's and Borland's IDEs are free. Personally I use Sun One Studio (formerly known as Forte) for everything Java related.
When Java was first invented (yes, I'm that old) I did use the Sun IDE (which wasn't free at the time, but wasn't bad) but I've never used any Borland product.
I shall have a look at the other two but being from a Unix background, I am biased in favour of Sun. I did try installing the SE SDK on my Linux laptop, but the documentation was non-existant for Linux and all the Linux howtos/tutorials seemed to have small but significant variations. I ended up having installed it (correctly I think) but not being able to compile anything because I didn't know how to use bldmake or makmake.
I do quite like Java, but I've always thought that it is a bit of a Noddy language compared to C (I have to confess, I've never really liked C++).
Hmmm... so far so bad. My ISP must be having a problem as I haven't been able to access any Sun site for the last 20 hours, how irritating.
