7650 Radio
10 replies · 3,083 views · Started 15 May 2003
Is anbody aware of an app for the 7650 which will enable FM radio ala 8310.
Would be a good idea don't you think?
:robot:
Ta.
Already been asked once this week...
The answer is, it would be a miracle. It hasn't got the hardware for it, software isn't the issue
I guess it could be done... Through streaming audio via GPRS, but it would cost a packet at the end of the month! 😃
Anyone know the Kb/s of GPRS?
[quote="nk8"]can't you just put up with a handsfree kit with a radio built in?[/quote]
that's the only solution I can think of, if not this, forget about it
I get a steady 6.KBIT per sec on my gprs. Gprs maximum is 43.2k for the 7650. Realone player allows u to stream audio/video. From adam. Cal me if u need any help. 07929345451.
[quote="Adam-07929345451"]I get a steady 6.KBIT per sec on my gprs. Gprs maximum is 43.2k for the 7650. Realone player allows u to stream audio/video. From adam. Cal me if u need any help. 07929345451.[/quote]*hint* 6 kilobits = 0.75 kilobytes 43.2kilobits = 5,4 kilobytes
