How to sort entries in Jotter
3 replies · 2,837 views · Started 15 May 2003
Surely there must be a way of sorting entries out alphabetically or manually. Any one know???
I don't think that you can sort the notes, they are sorted by date.
Ha ha, I can't believe I found this. If you delete a Jotter entry (Delete Note) and then immediately Undo Delete, it will put the entry to the bottom of the pile. So with a bit of patience, you can get your notes in the order you want them.
I can't believe I found that purely by chance - but it's certainly made my day.
Anis (UK)
[quote="AnisKhan"]Ha ha, I can't believe I found this. If you delete a Jotter entry (Delete Note) and then immediately Undo Delete, it will put the entry to the bottom of the pile. So with a bit of patience, you can get your notes in the order you want them.
Anis (UK)[/quote]
SO you are planning to sort it out manually this way? After yours can you do mine? 😃
