do rm files
5 replies · 1,267 views · Started 15 May 2003
i try to do rm movies with real producer 8 but when i put configurations
Video:
80 kbs
Smooth motion
20 fps
Audio:
8 kbs Music
Size 176x144
2-pass encoding
high quality resize.
the movies are big if i conver movie with 9 Mb stay 3 Mb what i am doing wrong somebody explain how can i do god movies like people put in forum
thanks
burt if i put 10 fps the movie is to slow and continues 3 Mb 😞
i like do movies for my 3650 but i guess i cant fuck
The frames per second make no difference to the file size - it's the bitrate that does that..
If you lower the frames per second but keep the bitrate the same your image will look slightly sharper but the motion will look shite and jerky as if you have skipping frames..
20 fps gives good motion and image quality for an 80kbps movie.
If you want your files to be smaller, then lower the bitrate - from 80 down to 40 or 30 kbps..
But with lower bitrate, again your movie quality will suffer so in this instance you may want to lower the frames down to 15 or 18 to give more bits over to the quality of your movie - 10fps will always look shite..
Best
Will
ok but the images suks, how you do matrix with best quality what setings you use?
