Hello all,
What's the best way to clean the Communicator screen? Is soap and water ok? Or window washing fluid diluted with water?
Hello all,
If your talking about the internal screen then get some screen wipes (PC shop), or use a damp cloth (not wet - just damp - and no detergents).
Hope this helps
I use Displex.
It's working great.
anyone of you guys uses a "protective film" on ur communicator screens?
like the one you see on palms and ipaqs... just curious coz i have plans using it...
i use the same cloth that comes with my sunglasses/eyeglasses
works well
