how do u save specific files?
3 replies · 1,852 views · Started 16 May 2003
I want o get rid of some the the java games installed in the applications directory such as splinter cell and others, but i want to make a copy on my pc so i can install it again, but at the time i downloaded it via sms so i dont have copy of the sys file anymore, can anyone help,
thanks
Find any use any one of the free or commercial File Manager tools that lets you copy individual files (e.g., from phone memory to MMC or send them over infrared or Bluetooth to your PC).
does anyone knoe where the application folder is for JAVA GAMES? cant seem 2 find it,
[quote="guest"]does anyone knoe where the application folder is for JAVA GAMES? cant seem 2 find it,[/quote]
Depends if you install them on the phone or on the MMC..
As far as I know they are installed to
Phone: C:\System\midp
MMC: E:\System\midp
In there you can find the company names and if you go deeper in the directory you will finally find the installed java files.
If I am wrong, please do correct me 😉
