mrouterserial.dll - i'm pulling my hair out!
3 replies · 2,158 views · Started 16 May 2003
God damn, this thing is doing my head in! ok, so i've done a search and read loads of topics on this, and I seem to have the same problem that everyone else had with PC Suite 1.2.
Ive overwritten mrouterserial.dll with the same file from version 1.1 whilst the program was not running.
Yet still I get the same message saying this is the 1st time you've connected your phone. All the ports are showing and i can tick all the ports to search for bluetooth devices. Yet i click OK and nothing happens. I can only click 'close'. I have mitsumi BT software loadded ands eveything works fine with that.
What on earth is going on!!!
I can pair with my computer via my Mitsumi bluettoh software but that doesnt seem to help.
All I want to do is back up my contacts so i can restart my phone and put the contacts back in there.
Apparently i can back up the file contact.cdb or a file similar to that but I can not send this file through my bluetooth software. I have Fexplorer and cannot send it via that either.
Am I missing something obvious here or is there any other way I can do this?
The contacts.cdb can be copied from the phone if its on flight mode.
To go to flight mode you need System Tools from psiloc.
1. Install System Tools
2. Go to flight mode
3. start FXplorer or any file explorer
4. Copy the contacts.cdb
5. Go back to normal mode
6. Format phone
7. Install System Tools
8. Go to Flight Mode
9. copy contacts.cdb back
10. Back to normal mode.
Or get the PC suite working 😃
I found a 'flight mode' in sLauncher too.
Not sure if it's common knowledge...
Turn the phone off
Plugin the charger
Press and hold the menu key
sLauncher opens up with no other apps running!
AND you have 4.5 mb of RAM!!
Great for running apps that are memory hungry like Opera or DOOM
