I have a problem with the C++ source code...
I'm working with the Symbian SDK 6.1 for Series60 Platform. I'd like to create a "code query" window when i click on my self created menu item. the Problem is that the C++ source code is not working properly. During compiling the projectfile an error is caused in the avkon.rh file. The error message is, that the STRUCT DIALOG is not found in the avkon.rh file.
Is there a solution for that problem, or should i write the STRUCT DIALOG by myself? If yes, how?
Gianni
