Move game to another folder?
10 replies · 2,759 views · Started 16 May 2003
How can i move installed programs to other folders? Like, if i have installed Rayman, how can i move it to another folder??
Please anwser! :robot:
Select the apps, press left softkey, select Move to folder from there.
Easy as pie. Read the manual that came with the phone. It usually helps.
I have tried the following:
I have tried to move an shortcut/program from the folder apps./program to the folder "games", but in the menu there is no option "move to.." if you now what i mean.
What should i do?
I've been trying the same thing with no success and I've READ the manual 😊
I'm not sure it's possible - if there's a way it's certainly not obvious.
Maybe move the file manually using extended manager or seleQ?
If you figure it out, let me know.
Cheers
Jag
The Symbian apps that install to the main menu can be moved. The Java apps that install to the applications folder cannot be moved to the games folder. Other Nokia phones support the Nokia-MIDlet-Category: Game tag in the JAD file to install them into the games folder; the 3650 does not.
But listen, when i wanna move a program to the apps. folder, it's not working! The move to... "apps" folder is not on the list! It's true!
u can download a app. such as smart luncher and that pro allows u to move anythin to any place 😊
