hi there !
I have a couple of questions, if someone could help me...
1. How can I select a specific tone for a group of contacts that I created like "Family" or "work"
2. why is my contact list so slow, when i browse through menus..?
3. is there any way to send contacts via IR to a normal nokia phone ? the problem I found is that contacts with photo the IR transfer simply aborts, and I cant find a way to send only the contact whithout the photo.
4. any suggestions how to create contact bases or tweaks to speed up the browsing ? I tryed to create a new but the comunicator simply doesnt recognise the number when someone phones or sends an sms, unless the contact base is in the memory card...
thanx in advance !
woww, I guess no one will answer this post..... damn :/
I hope that doesnt mean theres no solution for my problem... 😃
1. Ring tone for groups cant be done!
2. Mmm.... they seem to have fixed this on the 9210i. Had the same prob on the 9210. (Must say some cool imp on the 9210i)
3. In contacts . menu, tools, settings, on the 2nd tab you can tell it to take off the sending off pics...
Pain in the ass though to have to change it.
4. Have no idea!
Oh well not much help at all but ...
If my memory is right you can do ring tones for groups its a bit complicated but can be done there was discussion of this on the forum
quite a while back I cant remeber the exct way of doing it
I tried a search of the forum but the search engine dont come up with anything older than last month is this a bug or were my search words wrong dont know
perhaps someone else can remeber
The topic you refer to is here:
http://www.allabouter6.com/phpBB2/viewtopic.php?t=299
It doesn't help however. 😞
The search is squiffy at the moment. See Announcement Forum.
Rafe
