mmc 256mb
24 replies · 5,595 views · Started 17 May 2003
Hi there;
Please let me know if I can use the 256mb for my 9210i.
It seems that its says INVALID.
Please help, if i need to upgrade the software.
thanks.
any help pls email me to [email protected]
I was told by the guy at compusa that the max the old nokia 9200 can hold is 64 megs, is this true? or is he a beefy liar?
[quote="The Godfather"]Yeah,but 128mb is quite pleanty of memory... :roll:[/quote]
No its not! :x
Videoclips, 100's and 100's of them!
I am sick and tired of changeing the mmc's over everytime I want to
watch another set of clips! :cry: :x
Is ther already a 256MB MMC?
Well, if so, then LUCKY U! :P
Its stil not quite avail hir in our country. Talk about slow progress! 😞
Ive bin hearin rumors thou.
Anyway, im definitely sure dat SD cards wnt work on them, & if im not mistaken there already is a 256MB, 512MB or even a 1GB SD.
Correct me if im wrong. wud appreciate it.
Well i believe there goes a saying... " Man can never be content w wat he already has!" We will always strive for innovations, thus advancements! In short U can never have enuf of mem! jst imagine arnd 10yrs ago where a 40MB hard disk is already said to be big! Now wer talking abt GB! and soon TB! (Terra Bytes!) when wil dat b? :roll:
I tried the TEC 512MB MMC, that gives lots of strange errors when running apps installed on it or accessing data files from it.
I've just got a secondhand 9210 with OS 3.62, stuck a cheap 256 MB MMC in off ebay and it works fine (?)
hiya,
i was reading on your posts... yep, there are a number of MMC cards available, but i'm not sure if they are available in the philippines... i'm here in the UK and there are tons of MMCs and RS-MMCs available here.. even in countries like china and hongkong... try searching one on ebay.. you can buy them there cheaper..
you can get a 256, 512, and 1gb mmc or RS-MMC (with adaptor).. you can use these on any nokia phone. of course depending on which type of card it requires (if it's the RS-MMC or the regular ones)...
hope this helps.. 😊
heyyhowudoin wrote:Is ther already a 256MB MMC?
