eprofile error.
3 replies · 1,788 views · Started 17 May 2003
Help! when i run a animation as a background in eprofile and somebody phones me, after the call i get a error on eprofile and the animation stops working. the only way to sort it is by restarting the phone everytime.
Does anybody else have this fault or is it just me.
Toby :cry: 😮ops: :cry: 😮ops: 😮
i get the same problem. though it says some problem with "ePswitcher" or something, most of the time this happens when i get a call.
i emailed psi NT about it, they said try installing the latest ir-remote software, it worked for a couple of days but soon the problem returned!
What version of eProfiles are you running on? I recall about a month ago there was a thread here on the same issue, and it seemed that the problem disappeared with the latest version of the software (1.8 at the time). Check on Psiloc's site, they update their apps very regularly.
Paul
I am running version 1.71. That is it then. I will get the latest version and see if that fixies the problem. Thanks Mate. 😃
