I installed the commodore 64 emulator Frodo 0.50 on my 3650. It runs fine but i cannot run a game. I think that I should point to the game by using Disk commands->Select disk->point to the .d64 file
However the Disk commands->Select disk gives an empty list. It says NO DATA FOUND and I cannot browse to the file.
How do I get a game to run?
Ive been looking all over the net but there doesnt seem to be a decent manual on this program..
[quote="Pip"]However the Disk commands->Select disk gives an empty list. It says NO DATA FOUND and I cannot browse to the file.[/quote]
Have you sent the files to your inbox?
You can send them using BT and when in the inbox (They can be moved to a subfolder. I made one called Games under My folders.
When they are there, they should popup when choosing "Select disk".
Also. "Launch Game" should give the same list.
Hope any of this helps 😊
I send them to my phone using BT and Nokia Suite. I put them in the folder C64roms on my MMC.
E:\C64roms
You are right, the setup you are using works. But the games are located on your phone's memory right?
Can't I put them on the MMC and get them to work that way?
[quote="Pip"]You are right, the setup you are using works. But the games are located on your phone's memory right?
Can't I put them on the MMC and get them to work that way?[/quote]
In message section choose "Settings" and in there you can choose to have messages stored on your MMC 😉
Or this suggestion on how to copy them to MMC without using my method. Have not tried it myself though .. http://allaboutsymbian.com/phpBB2/viewtopic.php?t=9651&postdays=0&postorder=asc&start=30
And there is a gaming section here.. Think you might be a lot better of there 😉
-- cut ---
Edited a couple of times *lol* Now I am satisfied :-P
will do, thanks Tatus the Great 😊
[quote="Pip"]will do, thanks Tatus the Great 😊[/quote]
LOL.. erhmm. skip the great part.. Just helping out when I can 😉
Create a folder on your MMC:/documents/e32frodo/
You really should read the help file in frodo, there is many helpful hints in there.
the only thing thats in the helpfile is an internet link..
Read it a bit more. There is many pages of it.
Even if i download a 2 disk game(file) i can not play?! Why?? Pleas help my!
[quote="condorian"]where to download frodo?[/quote]
HERE 😃
