How do I install Webviewer (http//www.reqwireless.com) on the 7650?
The file extensions are *.jad (identification?) and *.jar (installation file?), and I haven't managed to get the application properly installed.
I figure that the file extensions are the ones which causes problems, *.sis files are installed properly.
Those are midlet(java) applications. The .jar file is enough for installation. Once it has been installed, it can be launched from Application(which means midlet).
You need internet access point(Do be messed up with wap access point) to make it working.
OK,
the jad-file seems to have messed everything up, now it works fine.
c.
how does the web browser work in7650, given its small screen? has 7650 experienced the NOT ENGOUGH MEMORY like 9210, given its very limited memory?
It's not a Nokia official applicaiton. The trial version can be found from www.my-communicator.com.
It works fine with N7650. There is no memory problem at all. Since the screen is small, complicate web page, like yahoo, looks really weired on the device.
But readable.
7650's screen and the WebViewer browser are best suitable for text-based web sites meant for PDA devices. At least here in Finland many news sites have this kind of a service.
I also have BBC World's ( http://news.bbc.co.uk/low/english/world/ ) and Wired's ( http://www.wired.com/news_drop/palmpilot/ ) PDA sites in WebViewer's bookmarks.
Tero
