Does anybody know if there is a decent PDF viewer on the P800 or if there is one in development?
Reading Acrobat files on the P800
UTFSB
[quote="Alan"]Does anybody know if there is a decent PDF viewer on the P800 or if there is one in development?[/quote]
The built in viewer allows you to do it already, well its actually not built in you can install it from the CD that came with your P800 😃
[quote="Anonymous"]UTFSB[/quote]
Use the -blank- search button?
That one I like...
Forgotten usually fits very good when explaining it to ppl who can�t stand the F word� but the expression really looses its feeling then.
Well, to be honest the built in PDF viewer isn't always great. It depends on the file. 😊
Built in viewer is crap, you need to keep changing the size on every page. I know MBrain software produce some readers for other symbian devices so maybe they'll produce something in future.
But we are stuck with it as of the moment 😞
