Anyone know how to copy files directly to the mmc card using bluetooth ? when i try to connect, i can only copy to the internal memory. I have Bluetake dongle.
using bluetooth to copy files to the mmc card
i use pc suite for that!
you mean from PC to phone using bluetooth? You can change the memory used for messages to MMC if you like. Go to the settings of messages and select "Other Settings" or something and change the memory in use to MMC.
Thx st@rr, that did the trick.
no prob! Glad to have helped!
