Hi! I desperately need help with my SMS. I have problem sending my SMSs. when managing my message account, my SMS folder is not lighted, thus I can't access nor modify my SMS account. 😞
Can't send SMS
Try to reboot the device. If that doesn't work you will need to do a backup - format - restore.
How did this happen? What did you do before this happened? Have you fooled around with the file manager and accidentally deleted some system files? What did you install before this happened?
If you want help with a problem, please be more spesific.
I think, Raven is right. I also have the same problem (SMS tab is not highlighted) after playing with FileManager. Eventhough, I didn't delete anytihing, after using Filemanager, all my photos, contacts, tasks, calendar disappeared.
Forrest.
ya, i had the same problem when i deleted ALL the mail files from
my system/mail folder. this was definately a bad idea and now i have
been trying to figure out how to restore my phone properly 'cause the restore feature on pc suite wont work!
