why program icons disapeares after installing new app?
10 replies · 3,223 views · Started 19 May 2003
Everytime I install a new program "on phone memory and memorystik" all my icons disapeares... I have to take the memorystik out and put it back to get my icons back again. My firmware version is R2D
Is this a normal bug with everyone or it is just with me :evil: ?
please help
Its a normal bug 😊 Im so use to it already that even if the aps dont dissappear I pull out the MS and plug it back in anyway 😊
Yeah, I think it's a normal bug to, which happens after you've installed a certain number of apps. I've never had this happen untill I started to install more and more apps. Would be interesting to know exactly what causes this...
[quote="Zeraw"]Everytime I install a new program "on phone memory and memorystik" all my icons disapeares... I have to take the memorystik out and put it back to get my icons back again. My firmware version is R2D
Is this a normal bug with everyone or it is just with me evil ?
please help[/quote]
I have the same problem but my solution is to stop the system application with tracker's running applications screen. There are also freeware proggies that can do this. Works every time, it's easier and it saves the memory stick contacts.
ZhuBaJie
😉 Well normally u'll get that after the installation of apps thats related to AppForge, Java and the system file... It's always a good practise to restart your P800 after doing so... just like your PC i guess...
Before I use to restart my phone but nowadays I just pull the MS duo out and plug it back in 😊 Or just today, I discovered that you can still see the aps from tracker, I just run any ap and it refreshes the application list 😊
when i installed audio magic all my apps icon disapeared, so i removed my MS stick, when i put it back all my icons got arranged from 0-Z
How could i put them back in order like before.
This also happend to me before, I just had to arrange it all over again 😊
Thanks for replies guys 😃 SE must do something with this bug in R3A firmware
[quote="khelo_g"]how do i do that?[/quote]
On applications menu, click on the word application, a menu will pop out, click on set folders 😊
