Please, somebody can advice me How can I read attached file in my 9210 after transfered data from PC with softwarePC suite for Nokia 9210 ( I can read only email -no attached file, I do not know why???)
How can I read attached file in my 9210??? Help!
normally you should be able to save the attachment and read it/use it in your 9210
It mean, have to be connected to PC with cable and save attached file in my device-
Thanks- I will try again
I assume you mean that you get an email on the pc and want to save this on your 9210
Save it first on your normal pc and then copy it over to your 9210 using the 9210 icon on your desktop (after installing pc suite)
Did you install the file viewer?Maybe you can't open them... :roll:
Every attached file has to be saved to my PC and than copy to the Nokia 9210 no way to load direcly
Hard working, long time!
I have been using XDA O2 64 MB RAM much easy - need to mark to download- and that is all
Anyway Nokia have to improved alot of thing for 92**
What do you thing?
I download mail+attachments with my 9210. (with messaging through gsm dialup)
So I can save them from my mail to my 9210.
