PC-connection ?
3 replies · 2,239 views · Started 04 July 2002
Hi..
Is it posible to connect the new nokia to a pc, and transfer the pictures to the pc ?
Is it posible to add extra memory ?
yes it is possible to sent pictures to a pc via infrared, bluetooth
no, you cant set extra memory in the phone
greetzzz
Yes. The connection is made via IR or Bluetooth. No cable connection support.
PC suite is needed in PC site. You can do backup, restore, and transfer files, etc.
i have not got my phone yet but when i downloaded the nokia pc suite and installed it ...the screen came up not tested with xp might not work and it did not my pc crashed 3 times so i uninstalled it anyone have any ideas
