keyboard problems.. HELP!
9 replies · 2,706 views · Started 20 May 2003
i�ve just formated my phone, a week ago. and everything was looking really cool until now 😞
i was just surfing through my phone, and was supposed to write a message. but when i started typing, i couldn�t get letters.. only chars, and when i try pressing the "#^"-butten to the lower right, nothing happens 😞
and the sadest thing is, when i try preferences -> phone -> general, i won�t execute.. this is the message i get..
"program closed
gs
CONE14"
the latest program i installed, was "wildskinz".. maybe that has something to do with the problem?
heeeeeelp!! 😊
kim
It IS wildskinz - do a search, this problem has been posted many times..
Reinstall wildskins if it's uninstalled..
Enable it
reboot
disable it
reboot
check it's disabled
uninstall
reboot
You should be back in action
Some threads say you should also delete your system.ini file, but most people do not need to.
Also it sometimes does not appear to work first time - just repeat the above process again and you should be OK.
Best 😊
Will
what a lame app 😊
i�m at work now, and i�ve deleted "wildskinz". unfortunatly, i deleted it BEFORE i got this tip, so i�ve gotta reinstall it to get my phone working as normal. damn, i ain�t home (where my IR/PC suite is) before tonight..
and i�m sort of addicted to writing stuff on my phone. are there any other ways to get rid of this problem?
what happens if i delete system.ini? sounds scary 😊
thanks
kim
it won�t execute.. this is the message i get..
"program closed
gs
CONE14"
has this something to do with "wildskinz" aswell?..
kim
i did a little search, and found a solution to the problem 😊
i took a chance, and deleted system.ini and a couple of wildskin files that i found, and now everythings okey again.. phew!
but thanks anyway, guys! what a whack app, the guys who made it should have bug-tested it before they make people install that bullcrap on their phones 😊 they deserve a slap!
i think i�ma try that sLaucher program instead!
ah, happy again 😊
kim
Deleting system.ini will work, but then you also loose all your other settings too.
sLauncher is a great app 😊
Best
Will
do sLauncher do the same job, as wildskinz? 😊
can you change/add ur own icons with that app?
is it sLauncher u�ve used on ur "avatar-picture"? looks cool..
kim
Yeah, sLauncher is on my avator.
You can change the way your menu system works and change your icons and the names of your applications 😊
Plus the Taskmanager is much better than the default one.
Give it a go 😊
http://www.symbianware.com
Best
Will
this doesn�t slow down my phone? 😊
(i just have to be sure, before i install anything) hehe
kim
