Anywhere else to upgrade software version?
2 replies · 2,081 views · Started 20 May 2003
Hi all,
I have a 7650 here but it's using an old software version, I was wondering if there's any other way of getting it upgraded apart from taking it to an NSC?
The closest one to me isn't particularly close and it's in a rough part of town
cheers :angel:
Have u considered sending it by post ? Might take a little longer, but would save u the journey.
As far as I can tell, NSC's r the only place u can get ur phone flashed.
Rob.
Yeah, post sounds like the best option I reckon.
It was just in case it was a simple procedure you could maybe get done online.
Worth a try
