Anyone using P800 as a bluetooth modem with Pal/PPC/Laptop ?
2 replies · 1,952 views · Started 20 May 2003
Hi all,
I've done a quick search and not found the answer, hopefully someone can help me ?
I'm trying to use my P800 as a GPRS Bluetooth Modem with my Sony Clie TG50. Before anyone asks why do I need both it is primarily becuase the Clie offers native Office support via the excellent Quick Office Pro suite.
I have paired the two devices, they see each other and manage to send data back and forth and even start the dial up process but I only get as far as the "Signing On" message and then a message saying "Incomplete setup"
I am on Orange GPRS in the UK and using the following setup:
GPRS no = *99#
Init string supplied by Orange = +cgdcont=1,"IP","orangeinternet"
Has anyone out there in P800 land sucesfully managed to use their phone as a modem and if so what settings are you using ?
Thanks in advance.
You need to have something in the Username and password boxes. There is NO login for Orange GPRS, but Palm WILL NOT dial without something in there. I suggest username = "a" password = "a".
Well this is how I connected my t68i to my Clie NR70V and they shouldnt be much different. For more info you can also check out www.cliesource.com wireless forums. This is a tutorial I made way back when I still had my NR70V with Bluetooth Memory Stick.
SONY CLIE NR70V& SONY ERICSSON T68i/T68
GPRS SETUP TUTORIAL
EQUIPMENT NEEDED:
1.) Sony Ericsson T68i
2.) Sony Clie NR70V
3.) GPRS ready Sim Card
4.) Infra Red or Sony Bluetooth Memory Stick
SOFTWARE NEEDED
1.) Bluetooth MS drivers for the Clie if using the Bluetooth MS.
Note: For Palm OS 5, new drivers will be needed.
2.) XIINO from ILINX which allows you to browse on your Clie I.E. style.
http://www.ilinx.co.jp/en/
3.) WapManager which allows you to browse through wap sites.
http://www.telecom.co.nz/content/0,3900,202098-201470,00.html
4.) ClieMail for emai management.
Lost the link but will post it here once I find it.
Note: you will not find guides for using these softwares, hopefully I will be able tow rite guides for them in the future. All you will find here is how to configure GPRS on the phone and have your Clie and T68i connect.
SETTING UP THE PHONE
(Must be done first before setting up Clie)
1. Go to Main Menu (move the stick to the right)
Go to Connect press YES (or press stick)
Scroll down to Data comm. press YES
Scroll down to Data accounts press YES
Select Add account? press YES
� Account type: GPRS Data
� Name: myGPRS (any)
� APN: xxx.xxx.xxx (Get this from your provider, usually in the form of a web address like www.data.com)
� User id: mine is blank, Check with your provider
� Password: mine is blank, Check with your provider
� Save?: Press yes
2. Main Menu ---> WAP services ---> Options ---> WAP Profile
� Add Profile
� Name: GPRS
� Connect using: myGPRS (use the name you made above)
� IP Address: xxx.xxx.xxx.xxx( Get this from your provider)
� Save?: Press yes
� GPRS > Edit
� Chg Homepage: Globe Home
� Address: http://www.xxx.com. ( Get this from your provider)
If Using Bluetooth:
GPRS Settings for the Clie [With Palm OS Version 4.1]
Pairing the Clie with the Ericsson T68i:
1. [At the Clie]: [Home] > [Down Arrow at top right corner] > System > Prefs > [Down Arrow at top right corner] > Bluetooth
a. [At the Clie] Bluetooth : On
b. [At the Clie] Device name : [Put any name to identify the Palm.]
c. [At the Clie] Allow device to be discovered: Yes
d. [At the T68i] Main Menu > Connect > Bluetooth > Paired devices > Add device > Phone accepts
e. [At the Clie] Trusted Devices > Add Device >
f. [At the Clie] [The Palm is searching for bluetooth devices and the phone driver in use will then be listed in the discovery results window]: Ok
g. [At the T68i] Enter the passkey: 1234 (use any xxxx number)
h. [At the T68i] Yes
i. [At the Clie] [Phone driver is added to the list of trusted devices.]
j. [At the T68i] Add Palm to paired devices: Yes
k. [At the Clie] Enter passkey: 1234 (must be the same as the above number)
l. [At the Clie] Ok
Configuring the Clie
1. Go to System ---> Prefs ---> Connection
2. Make new connection and name it any name like �GPRS T68i ->BT�
3. Connect to: Modem
4. Via: Pick the GPRS phone driver in use ( Et68i Bluetooth Et68i I.R.)
5. Click Details and follow the instructions below:
a. Speed: 115,200 bps
b. Init String: at+cgdcont=1,�ip�,�internet.globe.com.ph�,,0,0 (This is what I�m using, yours may not need this seetings)
c. Press Ok ---> Press Ok ---> Would you like this to be the default connection for your phone application? > Yes
2. > Network ---> Service ---> New
a. Service : myGPRS
b. Username: <blank> ,(may require an entry please ask your service provider)
c. Password: <blank> ,(may require an entry please ask your service provider)
d. Connection: [Pick the phone driver in use] ( Et68i Bluetooth Et68i I.R.)
e. Phone: *99***1# ,where 1 is your CDN number (yours may be different please ask your provider)
I would like to thank Globe Telecom for there support.
For info on configurations with other products please check this site out:
https://www.myglobe.com.ph/myglobe/gprsmodem.asp
