What happened to the Doom patch?
4 replies · 2,200 views · Started 20 May 2003
hi all
I was wondering where I can get the patch that allows you to install doom
on to the multimedia card, as I cant find it anywhere or on wildpalm
Thanks 😊
Here you go, did you do a search?
I found it easy enough?
Will 😊
(Mod Note: Please give link to the Doom Patch homepage rather than posting the file here. Thank you)
