RepliGo is now available for Series 60. RepliGo allows you to view any PC document on your phone. You simply run it through a print driver or in some programs click a toolbar button. You then download the converted file to you phone and away you go. Repligo can be purchased or demoed via Handango.
Author's Description:
RepliGo converts, optimizes, and transfers documents from your desktop computer to your Nokia Series 60 (3650/7650) phone, including:
� Microsoft� Office documents; Word, Excel, PowerPoint�
� Adobe� Acrobat PDF files
� Web pages
� Virtually any other document, report, image, or file you can print such as Microsoft� Project files, Visio� drawings, WordPerfect documents, CAD drawings, maps, e-mails, and more.
Overview
RepliGo represents a breakthrough in document conversion technology and mobility. In a matter of seconds, virtually any document you have on your desktop PC can be transferred to your phone while maintaining the document�s original look and feel.
This includes Microsoft� Office documents, Adobe� PDF files, Web pages and hundreds of other formats. Once on your phone, documents can easily be viewed and shared with others using the supplied RepliGo Viewer. You can transfer the document using Bluetooth, infrared or e-mail.
You no longer need multiple programs installed on your phone to view different types of documents. RepliGo is one application that handles any document that can be printed and is specially tuned and integrated into the conversion of Microsoft� Office documents and web pages viewed in Internet Explorer 5.5 or greater. Special conversion technology has also been developed specifically for PDF documents.
