Are you using GSM's "Automatic Time Update"?
6 replies · 2,288 views · Started 21 May 2003
This thread included a poll: Are you using GSM's "Automatic Time Update"?
I'm curious... this features will set your device time according to the carrier's time, which is a very nice feature, but not all carriers support it.
Are you using it?
I am looking for a way to turn it off because that might be the problem with my clock going mad from time to time (that began after the firmware upgrade). I am sick of readjusting the clock....
Only thing I've found is that the sync software has an option on the desktop to sync your phone's time with your PC's time.
The sync'ing with the PC clock of course only works if the PC time is accurate.
I am embarrassed to admit that I have been baffled for three weeks as to why the clock on my phone was four minutes fast every morning. It turned out that my Win2k desktop's time was not set using ntp (as my Unix boxen and my XP laptop are) and was four minutes fast - doh!
At last I have the right time on my phone. This is quite useful as I don't wear a watch.
I don't use it. Once you set the phone's time it stays accurate pretty well, so no need to sync it with the PC or with the provider
