1. install MGS to phone memory
2. install all MGS games to phone memory
3. use file explorer program (eg. SeleQ), and edit the path of
c:\system\magic101\magic101.ini file, from c:// to
e://
4. copy c:\101\ directory and paste it in e:\
5. copy all files in c:\101 to e:\101
6. delete everything in c:\101\ EXCEPT the bin
directory.
after this... when u check the memory.. it will still show u that mgs n other mgs games uses phone memory... ignore it..
then when u check the free space in ur phone... u will be surprised.. 😊
good luck
how to edit the path idont see the function of editing the path
Or just go to their website and use the latest version of MGS for 3650 and they will now install and run from MMC anyway 😉
Best
Will
I think i will try idea number 2! 😃
me too ! lol.. whats their website url?
Its avalable for download @ my-symbian.com
Dont know their home website!
Their website is on their games main splash page..
Well it is on Pool & Karting anyways.
www.nmprod.com
Best 😉
Will.
ATTANTION: i have MGS with my old FW 2.50 transfered into MMC and no problem.
But in FW 3.13 you can transfer MGS into MMC too but here is bug. After transfer the sound came OFF and no way to hear sounds from this MGS games. Shit da fucka.
how did u edit the path???what does it mean ???
is it copy the file from place to another???
make new folder on the mmc and put the stuff in it????
usualy i got to file manager and see the file ****.ini check the path of it but i can see a function that allow me to edit the path of it
anyway
just tell me guys how did u transfare the ini file from phone to mmc??
thanks guys
sollution is quite simple.. transfer the file to the pc,edit in text editor and transfer back to the phone.. 😉
[quote="willbrady"]Or just go to their website and use the latest version of MGS for 3650 and they will now install and run from MMC anyway 😉
[/quote]
I tried that, you can install the games to 3650 but they don't all work (FYI I was using MGS 1.92 rather than 1.90). Some of them still have to be installed onto C: to run, it seems.
where can i download v 1.92?
Best
Will[/quote]
haha, its more fun if it takes 2 hours... 😃
