In details please
I searched all over but cant figure it out (and yes .. i will register, sorry
1) How do you connect to the internet ( i have adsl ) using the serial cable, and a windows XP as your host/gateway?
2) How do you (if the first solution isnt an option) on your PC download web pages and transfer them (the whole process, please) to the 9210 for offline viewing?
? Anyone?
There's a program that can do that first thing. Check the forums. I think it's called eInternet.
The second one is easy, i guess
Just save a webpage to your desktop and copy all html and map's to a map on your communicator.
_________________
Te creavit Dazler mirabilem, Te respexit ancillam humilem<font size=-1>[ This Message was edited by Dazler on 2002-07-05 1852 ]</font>
u need data line for your 9210
[quote="shamshon"]u need data line for your 9210[/quote]
Anymore info on this Dataline? (ie. Web Link)
