One question about webviewer
3 replies · 1,852 views · Started 21 May 2003
Just downloaded webviewer and currently trying it out. Its working very fine but I have one question about webviewer. Does it prompt you to choose the "access point" everytime a link is clicked? Or is there some settings to set to set the chosen "access point" as the default?
Thanks in advance.
Well,it has been a while since i used it but i think there is a seting for default access point.The seting doesn't work if you use BT internet sharing.
I am currently using BT connection to try it out. But even if I use the GPRS access, it also prompts me for the same thing. Hmm... and i have just looked thru the settings, no such option for default access point. 😞
Yeah, 'normally' you just choose the access point once a session.
But if you are trying to surf over BT then it'll ask at every link you click..
Best
Will
