Hi
I can normally send faxes from my communicator but I can't recive it!? What is the problem!! When the phone rings, and I answer, I hear the fax tones, but my 9210 doesn't takes any fax messages???? Any suggestion
Thanx in advance
Hi
Thanx in advance
Yes the Communicatorn is capable of sending and receiving faxes!
Sending is easy but if you want to be able to receive faxes you must 1st go to your Network operator and have Mobile Office Activated (It wat it called hir!) Once Activated, You will receive 2 new GSM Numbers, one for DATA and the other for FAX!
You must advise who ever wnts to send fax to ur phone must now dial the new FAX number and not your current one.
HOPE i helped! 😉
