Adding application with security
0 replies · 2,093 views · Started 21 May 2003
hi Every Buddy
When I try to add an application on P800 with security (Keys generated using makekeys command with self signed certificate) as SIS file (generated using 'makesis' command), it gives an error "......". Is this because the certificate is not present in the Certificate Manager. If so, how do you add the certificate to the Certificate Manager when using emulator?
