Hi All
I have just bought a communicator second hand, but seem to have a few probs.
First and worst every few minuits the 9210 disconects itself from the computer i am using the data cable that came with it also how do you find out the firmware and software versions and where on the net is the best place for software and ringtones backgrounds etc.
I have looked and found a few but figured you guys would be the best source of knowledge, i have solved a few other problems with the help of messages in this forum.
Keep up the good work guys.
Starbuck
New Owner needs help
The original software is found on www.nokia.com. You could format your communicator and just reinstall everything, that might solve allot of your problems cause you can start with a clean communicator.
I got most of my software from the archives found on www.my-communicator.com, you'll find everything here you want. This forum is packed with other links to good sites.
Have fun
