Hi All,
Did anybody achieve following working constalation:
connecting P800 Emulator through the RAS to Windows XP ???
I try almost everything - i do not know what else.
I can see usually "In Use" message on the emulator. I use Com-Port Monitor util too see what is happen and COM1 is really allready blocked, but it is blocked by the emulator itself (after it starts)!
I have removed problematic .esk files, but it did not help.
I set comms database as simple as possible.
I set the communication speed as slow as possible.
I have tried the "nokia + virtual serial port" solution - but I did not find that mRouterLite.exe
I connect my nokia communicator (the emulator and the real device as well) to my XP RAS without any problem.
At least write to me please, that it is possible to bring it to work at all !!!
I do not want to spend other long long hours in afford without winning possibility.
Thanx a lot
hanshank
