I am looking for a software which converts .avi files into .3gp files. Does anyone know a URL where I can download it? THANKS :roll:
HELP: Coverter needed from .avi files to .3gp
Do a search on this forum and you'll find lots of different ones.
But here's one to start you- www.packetvideo.com
Download the trial of PvAuthor - its 60 days. This is a lovely convertor- you end up with .mp4 files, but just rename them to .3gp as its the same.
there's one in nokia.com right?.....and when you use the pc suite, if configured correctly, will automatically convert what you are transfering from your pc to your phone.........
Tried to convert an avi file to 3gp uing pvauthor. This was the trial version. It said it could not process the source format (the avi file). any ideas?
