Hi guys,
I'm trying to develop a Bluetooth application for my P800 mobile phone. I was wondering if this is actually possible at all. If yes, is it possible with Java (or C++)?
Thanks.
Hi guys,
Thanks.
[quote="mjx"]Hi guys,
Thanks.[/quote]
Hello, if you download and install the UIQ SDK you will find the full C++ SDK documented there. It describes the Bluetooth functionality available.
There is no Java Bluetooth API's provided for P800.
Hey man,
Thanks for your advice. I was thinking that no one would advice until u came long 😃
Too bad Java is not supported. There has been so much hype in the java website about Bluetooth, but not much action taken so far 😞
Blluetooth is suported in MIDP 2.0, so you'll have to wait for the SE guys to make the support...
